Multifunction DAQ
cDAQ 9185 network error recovery
I'm trying to add automatic recovery from network errors to my application (just in case). I'm creating the errors simply by unplugging and re-plugging the Ethernet cable on the cDAQ-9185. The device is directly connected to my computer using a static IP.
I'm reading a single TC channel, with continuous sampling. When I disconnect the cable, I get error -201390 from the DAQmx Read. So far good, I can detect the error. However, recovering seems to be difficult. So far I've tried:
1. Do nothing, continue reading as if nothing has happened. Reading actually recovers after while and the y-data is correct. However for an unknown reason the timestamp from DAQmx read jumps back to epoch and stays there.
2. I read in some forum that resetting the device would help. So I've tried calling DAQmx Reset Device. For unknown reason calling this VI in this situation hangs eternally. I actually need to reboot the Windows to recover. Even Windows hangs at reboot so I need to power off the virtual machine I use for development. I've tried using ping to detect connection to the device before calling the reset. Makes no difference. I also tried calling self test, same behavior.
3. I've tried stopping/starting the tasks, re-creating the tasks (the tasks are created programmatically). I get errors suggesting to reset the device.
Is this the expected behavior? Has anyone done this successfully? I have not tried on another VM or computer, also not with another cDAQ device.
Unfortunately I cannot share the code at this point. I'll try to create a minimal version for demonstrating the error and post that later.
Message 1 of 1
(748 Views)
