06-05-2015 05:21 AM
Hi I have a cDAQ9181 with a NI 9239 device inside as a network device. When I attach the cDAQ9181 to our corporate network the Measurement & Automation Explorer has no problem in finding the device, then I simply click "add device" and the drivers of the NI 9239 are installed and I can start collecting data.
This should also work when I directly connect with the device via an ethernet cable according to the documentation, however when I do this I can only get as far as finding the device and when I want to add the device so that I can see the NI 9239 I get the following error:
So I thought it might have something to do with my firewall settings so I turned everything off but I still got this message. Then I tried using a different switch but still got the same error. Could someone give me any fresh ideas to try?
06-10-2015 02:59 AM
Hey Gert,
I believe you have some issues with the IP addressing. Is the device with DHCP settings and your computer on Obtain IP automatically?
Check this thread: http://forums.ni.com/t5/Multifunction-DAQ/Error-201401-when-Add-Device-on-cDAQ-9188/td-p/1840983
Cheers!
Bozhidar
06-10-2015 03:05 AM
Also this is a good starting point: http://digital.ni.com/public.nsf/allkb/E67B4E4749F378FF862577270059BD4B?OpenDocument
