02-11-2009 08:11 AM
02-11-2009 01:32 PM
marloman,
cDAQ-9172 chassis has two internal counters that can be used for this kind of measurement. The catch is that you need to install the correct type of I/O module in either slot 5 or 6 to route the incoming signal to the internal counters. What I/O modules do you currently have installed? What version of LV are you running?
02-12-2009 07:28 AM
02-12-2009 08:41 AM - edited 02-12-2009 08:44 AM
marloman,
You need to install a digital I/O module in either slot 5 or 6. The 9241 9421 (dyslexia?) module should work for this purpose. The manual for the 9172 http://www.ni.com/pdf/manuals/371747f.pdf has a section dedicated to using the counters. See here for info on making the internal counters visible in DAQmx terminal controls/constants. http://digital.ni.com/public.nsf/allkb/DF48BC8CFFA1F6CB86256F5D007EA11A
