Multifunction DAQ
cDAQ-9137 Windows Controller - what's the default/factory static IP?
Dear All,
I've a cDAQ-9137 Windows OS and I cannot access the video output to attach a monitor, and I'd need to set up a Remote Desktop connection to develop my application:
since I haven't found the default static IP, could you please let me know what's the factory default?
Even DHCP would be fine, but still the documentation is needed
Thank you very much!
Best Regards
(1,034 Views)
Hi Davide,
there are several ways that you can try (just theoretically since I can't test them):
  1. point-to-point connect the Windows cDAQ to the host PC and check if it's recognized in the Network section of the host PC;
  2. same as 1., but using a tool (e.g. Wireshark) to scan the IPs on the cDAQ-PC network;
  3. look on the datasheet if there is an IP reset procedure.
Hope this helps!
Alessia
(996 Views)
Thank you very much, Alessia!
you'd been very fast and efficient
(993 Views)
