10-03-2022 03:25 AM
I have a system using 68 pin multifunction cables, from the (bought-out) analog front-end to the PCIe-6323
The cables are 68-pin on both ends.
I need to be able to take some of the analog signals into an oscilloscope
I took a look at using the SCB-68 breakout box, but I don't think this is what I need - I would prefer not to break any of the connections if at all possible.
Any suggestions?
10-03-2022 08:59 PM
You can get the BNC accessory as listed on this compatible accessory page
If you need every one of the signals on 6323 on a BNC cable, you are better off outsourcing to a cable assembly vendor to put together your "custom" cable.
