What you're asking for is a mass-terminated device - something that allows you to connect via cable. There are such devices for USB, including the
USB-6225,
USB-6255,
USB-6251 and
USB-6259. There are multiple variants of these devices, but if you use the mass-terminated version, connectivity is provided through one (6251) or two (6225, 6255, 6259) 68-pin SCSI II connectors. To maintain signal integrity, it's recommended to use the SH68-68-EP cable to connect up to any of the 68-pin MIO connector blocks.
If you prefer custom connectivity solutions, you can consider making a custom cable to connect up to the SCSI connectors or consider the
SH6850 cable.
Finally, you could consider the USB M Series OEM devices. As previously mentioned, those come without a shielded casing and provide connectivity directly through IDC headers. There's an excellent
OEM user guide giving you information on dimensions and connectivity should you choose to go that route.
Thanks, JaredA
