automatic instalation of a simulated card
Hye !
I would like to make an automatic install of my LabView program...on a machine qhich not have a DAQ card...
For my scolar project I would like to make an install exe, as to my professors need only to launch an install file..
This installation firstly install NI DAQ mx, then the cards (PCI 6229 and 6503) and finally the program files....
Is it possible to install automatiquely a simulated card ?
And so Do you know the way to make install processus of LabVIEW program ?
THANKS
Julien
Conception Informatique et électronique
CNRS LCSR Web
Orléans la Source FRANCE
(2,222 Views)
I don't think you can create automatically a simulated device.
However, you can easily create with LabVIEW 8 an installer including a driver (DAQmx for instance). You have to join the driver to the installer when you configure it.
If you don't have LabVIEW 8, you have to create a batch file which launch the driver setup at the end of the installation of the program.
You'll find more informations about this at the link below :
http://digital.ni.com/public.nsf/websearch/E09BA0E2F31D304F86256A640070058E?OpenDocument
Benjamin M
NIF
(2,199 Views)
