I want to measure a frequency on the analog input but it doesn't seem to work.
I'm trying to get it working using DAQmx with the use of ansi c.
The first step I made was acquiring the information on the analog input. With the use of a simulated device this shows a sine wave on the input.
My next step was to generate a trigger signal for the counter, but this doesn't seem to work.
I don't see how it is possible to connect the trigger on the analog input to the counter.
For the creation of the analog input and trigger I use the following code:
DAQmxErrChk (DAQmxCreateTask("",&taskHandle));
DAQmxErrChk (DAQmxCreateAIVoltageChan(taskHandle,"Dev1/ai0","",DAQmx_Val_Cfg_Default,-3.0,3.0,DAQmx_Val_Volts,NULL));
DAQmxErrChk (DAQmxCfgSampClkTiming(taskHandle,"",10000.0,DAQmx_Val_Rising,DAQmx_Val_FiniteSamps,1000));
DAQmxErrChk (DAQmxCfgAnlgEdgeStartTrig(taskHandle,"Dev1/ai0",DAQmx_Val_RisingSlope, 0));
For the creation of the counter I am using the following code:
DAQmxErrChk(DAQmxCreateCIFreqChan(taskHandle1,"Dev1/ctr1", "",1,2000,DAQmx_Val_Hz ,DAQmx_Val_Rising ,DAQmx_Val_LowFreq1Ctr ,1,4,""));
I hope some one could give me a hint.
I have also tried the examples that come with DAQmx but far as I know this are only counter examples using digital inputs.
Thanks in advance.
