after install. : windows prompt: 'code 10' can not start device [pxi 6224,6723]
Hi.
I use an industry pc, which is connected via pcmcia card to the pxi module [8310]. All control lamps are burning which means, that computer and pxi are able to communicate. When I start the industry pc it recognises the inserted pxi modules 6224 and 6723 and starts their installation. After installation I get a prompt from windows,  [code 10 can not start device].
If I start Max, the devices are not listed. On an other PC it works properly...
Thanks for help
(2,952 Views)
Hello Tie,
could you post your email address so that we can increase the speed of the support.
I will post later the solution of the question.
Kind regards,
Elmar
(2,935 Views)
