Multifunction DAQ
acquiring tempterature signal and display in PDA
hi.
may i know how to create a program to measure temperature and show the data using a simple numeric indicator using PDA ?
(3,665 Views)
Hi Alonso,
We have several options available.  You will need three main components to make this work.
1.) DAQ Hardware to take the thermocouple measurements.  We have three groups to choose from: PCMCIA, Compact Flash, and USB devices.
2.) DAQmx Base Drivers so that your PDA can talk to the DAQ Hardware.
3.) LabVIEW and the LabVIEW PDA module to run the software.
There is much to discuss on this subject and I look forward to working with you on your application but to prevent me from overwhelming you with irrelevant info, can you please tell me how much of the above 3 you already have.  In particular I am interested in the type of PDA you have, what OS it is running, what DAQ hardware you have (if any), what version of LabVIEW you have (if any).
Thank you very much,
Jeff Tipps
(3,645 Views)
