10-13-2008 09:33 AM
Solved! Go to Solution.
10-13-2008 01:29 PM
NEW INFO:
The accelerometer is a single ended output type. The excitation voltage is 18-30 V
I connect one of the wires from the sesor to ACH0 and the other one to the + of the power source and i use the test pane under the Measurement and Automation application I get no response... I have the channel properly selected and I have NRSE selected under the input configuration. Am I missing something?
10-13-2008 02:54 PM
You need a ground return path- connect the power supply ground to the analog input ground on the DAQ card.
-AK2DM
10-13-2008 03:05 PM
The accelerometers you are using require an ICP power supply. This is a constant current source of 2ma or more and a constant voltage of 16V or more. NI makes several devices with the required power. Regular DAQ board power supplies WILL NOT WORK. So the reason you do not get the accel to work, is it is not properly powered.
Consider the USB-9234 or the NI-9234 in a CompactDAQ chassis. This device is designed to work with accelerometers.
http://sine.ni.com/nips/cds/view/p/lang/en/nid/204481
You can equip your DAQ board with a ICP power source using our SCC modules:
http://sine.ni.com/nips/cds/view/p/lang/en/nid/12312
http://sine.ni.com/nips/cds/view/p/lang/en/nid/202603
You can create a 2 wire to BNC cable with one of these:
http://sine.ni.com/nips/cds/view/p/lang/en/nid/1721 - look at the BNC connector panelette
Let us know how this helps.
10-14-2008 06:59 AM
Thanks a lot for the help. It seems like something is perhaps wrong with the DAQ card or my SCB-68 the reason being is that when I attempt to connect a DC power supply to the ACH0- and ACH0 and go into the test panel to see if it reads a voltage diffrencial I don't get anything, i'm inputting between 0 to 5 volts. Also the 5 volt power output on the SCB-68 reads nothing when i put a voltmeter up to it. The DAQ card passes its self test so i'm assuming that in terms of set up its correct in that aspect. Am I missing something?
10-14-2008 09:10 AM
Yes, I think you are missing something. The sensor requires 16 to 30V DC and 2 to 6ma of current. The power on the DAQ board does not provide this power.
10-14-2008 10:00 AM
The problem was with the installation of the PCI card. I changed the PCI slot and it worked perfect. Thanks for the help!
