11-20-2011 02:35 PM
I have been working on a code which utilizes daqmx assistant to read and write strain, temperature and voltage from a cdaq-9174, with cards NI 9211 and NI 9237. Everything works fine in the code but I want to be able to zero the strain data at the start of a test.
I have been trying to create a way to make it so I click a button and it will zero just the strain data like an autobalance. Does anyone have any suggestions on how to accomplish this?
Solved! Go to Solution.
11-22-2011 11:06 AM
Hi Fwowe,
From what I understand, you are trying to to have is a tare. I've programmed a little VI that acomplishes that task.
Take a look at it and tell me what you think.
Best Regards!
Carlos O
11-28-2011 01:11 PM
Thanks Carlos that was exactly what I needed.
01-24-2012 05:42 PM
Can you post a picture of your vi? Using LabVIEW 8.5.1, I currently capture the output of the DAQ Assistant in a Waveform Graph and then substract it from the data. This works but sometimes the vi crashes and I'm curious about your solution.
01-25-2012 09:51 AM
Hi djemb!
I hope this helps!
Kind Regards
Carlos O
01-25-2012 10:26 AM
Thank you Carlos, do you have a suggestion to do the same thing with DDT? Our DAQ Assitant is configured to collect 6 strains gages at 20 Hz with 5 sample deep buffer.
01-31-2012 01:35 PM
Hi djemb!
You might want to try to use this code as a subVI in your original program. Take a look here to see how to create subVIs in LabVIEW 2011.
I hope this helps.
Cheers!
07-15-2014 12:44 PM
Hi Carlos,
Thank you for the VI that you posted online to zero strain. By using the VI that you provided, i tried to zero out the strain. But i am not able to get any kind of strain readings in the output ( Waveform Chart ). Attached is the block diagram. Can you please suggest me the changes that needs to be made in this
07-15-2014 01:04 PM
07-16-2014 02:23 PM
Thank you,
Got rid of it and it is working perfectly fine. I have a question though. How to plot force v/s strain graph in Labview? I have a NI 9237 to measure the strain and a load cell to measure the deflection. Can i know how to synchronize both the signals and get a graph of Force v/s Strain?. I need help with the VI. Would greatly appreciate if you post the VI for me
