Multifunction DAQ
Windows did not recognize my board PCI-6225
Hi all,
I have installed NI-DAQmx 9.0.2 and then I have installed my hardware which is a PCI-6225 board.
Windows (XP SP2) did not recognize my device.
Does anyone have an idea on my problem?
The configuration on my computer is:
Pentium 3 1.00GHz
(3,492 Views)
When I said Windows did not reconize my board PCI-6225 it means that the device manager does not see the card...
Any suggestions?
(3,488 Views)
Hi Bravi,
Have you tried in another PCI slot? In another computer?
You can also try to upgrade to the last version of NI-DAQmx (9.2.2).
I hope this will help,
(3,463 Views)
Yes I tried another slot PCI and the problem is still there.
Yes I tried another computer and the board PCI-6225 worked correctly.
I am currently upgrading my version of DAQmx from 9.0.2 to 9.2.2 and I will tell you later the result.
Thanks for your ideas.
(3,461 Views)
I updrage my version of DAQmx and the problem is still present...
Any other suggestions?
(3,458 Views)
