‎01-21-2011 03:45 PM
My computer with Windows 7 often hangs or crashes when trying to go into sleep mode when USB-6210 DAQ is plugged into the computer. The first time that I try to put my computer into sleep mode after rebooting, everything seems to work fine, but after waking the computer and trying to sleep it a second time, the system hangs. The monitor shuts off, but the power LED on the computer is still illuminated. If I unplug the USB-6210 at this time, the computer goes to sleep immediately and can be woken later without any obvious trouble. Occassionally, the computer just crashes when I try to sleep it with the USB-6210 attached (indicates that Windows did not shut down properly when I restart it). I have several other USB devices such as hard drive, mouse, keyboard, USB-9162 with NI 9481 attached to the computer, but have isolated the problem to the USB-6210. The problem does not happen if everything but the USB-6210 is connected and happens if the USB-6210 is the only thing connected. This problem does not seem to happen on my Windows XP Pro machine.
System configuration:
Laptop with Intel i5
Windows 7 Home Premium
NI-DAQmx 9.2.3
LabView 2010 32 bit (not running at the time)
USB selective suspend is enabled in the power settings
Any suggestions about what could be the problem and/or the fix?
‎01-21-2011 03:55 PM
Do you have anything connected to the USB-6210 when you try to put the computer to sleep?
‎01-21-2011 04:17 PM
Some analog inputs of the 6210 are connected to some passive circuitry, which is connected to some of the digital outputs of the 6210. When I disconnected the 6210 from the circuitry, the problem seemed to go away. I then reconnected the circuitry, but the problem did not seem to return.
‎01-24-2011 08:28 AM
Are any of the digital outputs sourcing current when you try to put the computer to sleep (e.g. driving a line high)? It's possible that there is a continuous power draw from the USB bus that is higher than the USB spec allows in suspend mode. I would recommend disconnecting your circuitry before putting the computer to sleep.
‎01-24-2011 08:28 AM - edited ‎01-24-2011 08:28 AM
EDIT: Double post for some reason.
‎01-26-2011 03:34 PM
I don't believe that the digital outputs are sourcing much current when the computer tries to sleep. The load on the digital outputs is around 6k ohms. I have not explicitly set the outputs high and a multimeter indicates no voltage across the load (the outputs must default either low or tristate).
