Multifunction DAQ
Windows 10 and cDAQ
Recently I have encounter a technical problem between New PC (with Windows 10) and cDAQ. Anyone have come across about getting loss connection between Windows 10 and cDAQ? PC and cDAQ are connected through Ethernet Cable.
I did tried to run in PC with windows 7, yeah i'm able to run the program smoothly without any loss connection. Is this something wrong with windows 10?
My application is running 24/7.
Thank you.
(2,007 Views)
I would bet dollars to doughnuts that there is a Power Manager setting on the new machine that is shutting down something that needs to say awake.
"Should be" isn't "Is" -Jay
(1,979 Views)
