Will the DAQ-700 card work with windows XP?
In one of the responses to an inquiry, someone stated that the DAQ-700 card will not work with Windows XP.  I would like to know if this is true.  I want to use the DAQ-700 card with Labview 6.1 and NI-DAQ 6.9.2 on a computer that has Windows XP.  If the DAQ-700 card will not work with Windows XP, where can I find that in the documentation?  Thanks.
(3,765 Views)
It says its supported here. If you ask about a specific question/answer on the forum, it would be nice if you provided a link to it.
(3,763 Views)
Dennis is right. The 700 is supported by NI-DAQ 6.9.3, which is also supported by LabVIEW 6.1 which is supported by Windows XP. So, you're good to go. Here are a couple more links (one and two) that in conjunction with the one Dennis linked show the rest of the compatibilities.
Chris W
(3,743 Views)
Thanks for your help.  I am providing a link to the post that I mentioned previously.  Reading the post again, it says that the DAQ-700 is not supported on Windows XP.  I interpreted this to mean that the DAQ-700 would not work on a computer with Windows XP.  I am not sure if that is a correct interpretation or not.  Here is the link: http://forums.ni.com/ni/board/message?board.id=250&message.id=26028&requireLogin=False
(3,724 Views)
And on that link there is another link that lists all of the DAQ drivers and 6.9.3 is listed as being compatible with XP. I can't explain the response by Eric J unless since then, the driver was tested with XP and the compatibility list was changed.
(3,722 Views)
