06-30-2005 05:54 AM
07-01-2005 05:41 PM
A few questions:
1) You said that when you try to reinitialize it doesn't work properly. What happens? Is there an error code that appears? Basically, how can you tell that it's not being initialized?
2) What programming language are you using?
3) I'm assuming if you stop the program and restart then the switches initialize correctly. Is that correct?
Thanks!
Brian Spears
