Multifunction DAQ
Why is my digital line in always reading low?
For some reason, my dio line in is aways reading low on my current application. I have several dio line outs that work properly, but the dio line ins do not. I tested the input line in Max, where it worked correctly. I also copied and pasted my dio vi into a new file and it worked correctly. Why will it not work in my current application?
(2,636 Views)
Hello bradle95,
Thank you for your inquiry regarding dio lines. It sounds like your dio input lines are always low. In this situation more information about your system configuration would help. Was the dio vi that you mentioned, from LabVIEW or did you create it? If you have an SCXI chassis configured as one of your devices in MAX, this will reserve DIO lines 0, 1, 2, and 3. In this case one possible solution may be to either use one of the remaining lines or remove the chassis in order to use these lines.
Also, if you are using an E-Series Board connected to a DAQ Signal Accessory, DIO line 6 will always appear low. This is because DIO line 6 is also the up/down input for the STC counter and is connected to phase B of the encoder knob. See the E-Series User
Manual for more information. This
Other resources like this can be found on the ni.com website by clicking the support tab at the top of the home page. Then search for �YOUR TOPIC� from Technical Resources at the top of the page or topics similar yours. I hope these resources help. Let me know if I can further assist you.
Shea C.
Applications Engineering
(2,636 Views)
