Multifunction DAQ
Which is the best cable to connect with a NI 6259 screw terminal DAQ?
(2,940 Views)
Hello Afrin
The recommended cable for the PCI-6259 is the SHC68-68-EPM (2m) (Part # 192061-02).  This cable will connect to all screw terminals with a 68-pin connector.  Note that the 6259 has two terminals so you will need two cables and two screw terminal blocks to gain access to all the terminals.  The recommended cables and terminal blocks are listed on the 6259 product page.  Here is the link
Chris_K
(2,916 Views)
