07-13-2006 02:46 PM
07-14-2006 02:25 AM
I would certainly not say cheaper
But you do have M series USB DAQ's that can support much higher update rates for Analog output generation
that would be NI USB 6251 and NI USB 6259.
Hope this helps
Regards
Dev
07-14-2006 08:45 AM
Dev,
Thanks for your reply. I looked at the two DAQ boards. Yes, the output rate is way high enough to do the job. However, it also has 16 analog inputs that I don't need. Do they have any Analog Output DAQ boards which have such a high Analog output rate? I guess I just don't want to waste money on so many analog inputs...If it's just a couple of AIs, that's fine.
Thank you very much!
Labveiw User
07-14-2006 08:55 AM
This site uses cookies to offer you a better browsing experience. Learn more about our privacy statement and cookie policy.
