01-13-2021 04:57 AM
We are researchers in France. Could you please help us to choose the right NI equipment?
What I have?
I have a Swagelok Pressure Transducers (S model).
My question is:
Thank you very much.
01-22-2021 01:43 AM
for measuring voltage in the range 0-10V you can use Ni USB 6001, 6002 series devices. They measure analog voltage in the range +- 10V. It has also an Analog output of +-10V 5mA, which I suppose is not sufficient for powering your sensor.
https://www.ni.com/en-gb/shop/hardware/products/multifunction-io-device.html
Ni has also cRIO chassis to which you can attach a Voltage measurement module like NI-9201. cRIO requires also a power supply of 9-30V which can also be used as a power supply for your sensor. However, this is a very powerful device with real-time measurement possibilities which perhaps could be necessary for further research.
https://www.ni.com/en-gb/shop/hardware/products/compactrio-controller.html
https://www.ni.com/en-gb/shop/hardware/products/c-series-voltage-input-module.html?modelId=122155
https://www.ni.com/en-gb/shop/accessories/products/industrial-power-supply.html
