‎05-05-2005 08:39 PM
‎05-06-2005 01:25 PM
‎05-06-2005 03:55 PM
‎11-11-2009 07:04 PM
Hi
We use VISA based Register level programming for E Series DIO channels for one specific purpose. We access only the following DAQ-STC Registers
DIO_Control_Register
DIO_Output_Register
DIO_Parallel_Input_Register
Window_Address_Register
Window_Data_Read_Register
Window_Data_Write_Register
The E Series RLP manual provides their address and offset correctly. We want to use the M Series Board and I am unable to find the DAQ-STCII RLP details. I tried the entire NI Site. Please provide the STC II registermap or atleast the register information of the above registers.
thanks and regards
Sathish
‎11-11-2009
09:24 PM
- last edited on
‎04-09-2025
04:47 PM
by
Content Cleaner
lIt sounds like you are looking for the DDK. There is a dedicated board for that.
p.s. Try to avoid posting to such old threads.
‎11-12-2009
10:44 AM
- last edited on
‎04-09-2025
04:48 PM
by
Content Cleaner
Hi Sathish,
Given how much blatant, undisclosed, and unrepentant cross-posting [1] [2] [3] [4] [5] you've done to ask this question, I gave you the benefit of the doubt that you were new to the NI forums and didn't understand the etiquette of this community. However, looking at your profile, you've been around just over 8 years! How can you be so selfishly impolite?
To your credit, you at least searched the forums to find (somewhat) relevant to which topics to reply, but as you said you 'tried the entire NI Site', I'm surprised that you missed the DDK home page [6] that has a link to the M Series register map.
[1] Re: m series register programming in straight C
http://forums.ni.com/ni/board/message?board.id=90&message.id=1644#M1644
[2] Re: Problems configuring a port in niPXI-6509 card as input port using static DIO Register Level Programmer maual
http://forums.ni.com/ni/board/message?board.id=90&message.id=1645#M1645
[3] Re: Problem with writing to registers
http://forums.ni.com/ni/board/message?board.id=90&message.id=1646#M1646
[4] Re: Is there a Register Level Programming manual for NI 625x PXI
http://forums.ni.com/ni/board/message?board.id=270&message.id=7661#M7661
[5] Re: Where Can I find information about register level programming the PXI 6259?
http://forums.ni.com/ni/board/message?board.id=250&message.id=53551#M53551
[6] Register Level Programming for OEM Customers
http://digital.ni.com/express.nsf/bycode/exyv4w?opendocument
Joe Friedchicken
NI Configuration Based Software Get with your fellow OS users
[ Linux ]Principal Software Engineer :: Configuration Based Software
Senior Software Engineer :: Multifunction Instruments Applications Group (until May 2018)
Software Engineer :: Measurements RLP Group (until Mar 2014)
Applications Engineer :: High Speed Product Group (until Sep 2008)
