05-24-2005 04:40 PM
05-25-2005 12:02 PM
05-25-2006 02:29 PM
I got a problem when I run my labview code. I got the following two errors.
In labview code I get this error immediately when I run it.
“Error –2147220727 occurred at DAQmx Create channel (Ao.voltage-Basic). Vi.
The error code is undefined. No one has provided a description for this code, or you might have wired a number that is not an error code to the error code output.”
Now when I tried to open MAX to see the device/interface I got the following error.
“nimax.exe—The instruction at “0x1cd6e15d” referenced memory at “0X0000002c”. The memory could not be “read”.
I have been using this labview code for last wix months. Never had any problem. However some viruses infected my computer recently and after cleaning it I try to run my labview code and got the above-mentioned problems.
I’ll really appreciate your help in this regard.
AM
05-26-2006 10:18 AM
DSPGuy1,
It sounds like after the virus either your MAX installation or DAQmx installation may be corrupt. So I would recommend uninstalling DAQmx, and then reinstalling it. Here is a link to the current drivers. Hope that helps.-GDE
