Multifunction DAQ
What is the wiring for the SHC68-68-EPM cable?
Can someone please verify for me that the wiring for the SHC68-68-EPM is sequential all the way across the connectors? It looks to me like pins 1 through 34 at the end with the 0.8 mm connector go to pins A1 through A34 at the .050 connector, (as AMP numbers them), and pins 35 through 68 go to B1 through B34. I just want to be absolutely sure before I lay out my printed circuit board. Thanks.
(2,697 Views)
The following KB article should help:
http://digital.ni.com/public.nsf/websearch/DE2D842E545DE64B86256F78006EAB1A?OpenDocument
It appears that the pin mappings are the same on both sides (.050 and VHDCI)
(2,686 Views)
