Using the NI-DAQ API (not LabView) will give you a significant amount of more control over what happens and when to the data stream; which translates to a more efficient program. But you need to program in C/C++ or Delphi then. The Measurement Studio provides ActiveX controls that are like the LabView ones for C&C++ (they�re slow like the LabView ones though � not a lot you can do about the Windows GDI).
What are you trying to sample 15000 times? The 512*512 pixel field?
That�s almost 15Gigs of data! And it means you need to process data at 12.8MB/s to finish it in 20 minutes. I hope you know C, x86 assembly and MMX.
I would setup a huge circular buffer (NI-DAQ calls them �double buffers�), about 30 seconds worth or so, to use with SCAN_Start. Then I would proces
s the actual buffer the card is DMA�ing the data into with a high priority thread. Progressively sum the scan values from the 16bit buffer (the samples are only 12 bit, but the buffer should still be 16bits wide) into a secondary buffer of DWORDs the size of the screen (512*512), and you�ll need two of those, one for each channel. Once the 15000 scans are complete, convert each entry into a float divide by 15000.0f, and store it in a third buffer of floats.
If you wish to contract this out, send me an email at shannon.barber@myrealbox.com 🙂
