03-30-2020 08:03 AM
Seen some devices with OEM and some without OEM. What is the difference?
I am new to the NI would, as a PMEL technician using Calibration Executive to calibrate devices NI devices, like the USB-6211, I noticed Cal-Exe lists a "USB-6211" and a "USB-6211 (OEM)", (for example); wondering what is the difference. Normally I would interpreter "OEM" as "original equipment manufacture", if correct why the list it in Cal-Exe?
Also, not sure if I'm posting in the correct area...
Solved! Go to Solution.
03-30-2020 02:04 PM
I think the difference is just in the packaging of the board. Hopefully someone else can explain the calibration executive as I have never used it.
http://sine.ni.com/nips/cds/view/p/lang/en/nid/203671/
https://www.ni.com/pdf/manuals/372083c.pdf
Bryan
04-07-2020 06:45 AM
hi, thank you for the reply. But still have same question about "OEM", specifically why does Calibration Executive have some of its listings with "OEM" and with out, for the same item.
04-13-2020 12:36 PM
OEM devices are for Manufactures who want the NI's hardware to be included in their big machinery. Example, image a robot manufacturer who wants to use NI hardware internally, so they get the OEM version and include in their system.
Typically OEM version of HW are delivered without enclosures and may be custom pinout so that the user (another manufacturer) can customize to their needs. Whereas the non-OEM version is intended for end-user (consumer/engineer) who just want to create a test system which could be one to a few for their project.
