For ArmStart you wait for on two different signals, the arm start trigger and the start trigger itself. Once the arm start trigger signal is received, the
counter becomes armed and is ready to start - only the start
trigger allows operation to begin. For Start Trigger, you just wait for the start trigger signal to be received. In your case, I believe you must be arming the counter before you call this function, so it looks the same to you.
