11-18-2008 01:38 PM
If I buy the DAQ are the drivers supported? What do I need to support a VB application?
11-19-2008 11:10 AM
giffcolts,
You are correct with the purchase of a DAQ instrument the drivers are supported. The drivers are compatible with VB we also build example programs to help you get started with your data acquisition. You can go here and get a good idea of the basic data acquisition procedure. Depending on the board you buy and the needs of your application you may need different things, but most generally you will probably just need DAQmx.
11-19-2008 12:21 PM
11-20-2008 11:12 AM
giffcolts,
There are MANY advantages of LabVIEW in this environment. If you are anything but a VB expert LabVIEW is much easier right out of the gate with its built in VIs that completely control all aspects of the data acquisition process and easily allow you an easy to understand overview of the entire program. In addition to the examples that I showed you for VB we have TONS of examples for LabVIEW for nearly any type of application. While the driver is the same the ease of accessing that driver is one of LabVIEW's strongest points. Rather than having to look up function calls, deal with all of the syntax, and other traditional programming pitfalls you get a simple yet powerful graphical interface that still has all of the same functionality. If you had more specific questions about your application I could probably direct you to some documentation and/or examples on directly how to do it. Please feel free to ask any questions you have!
