Multifunction DAQ
What causes Run Time Error 10086 when attempting an external calibration with the Calibrate_E_Series funcition.
I am using Vb6(sp5), NT4, Component Works (latest), and Ni-Daq 6.9.1. The error occurs when using either a PXI-6052E or PXI-6070E. The Self Cal works fine but the external cal code generates this error during the call. The code used is taken directly from the programming example in the NI_DAQ programmers reference for the Calibrate_E_Series function.
The Error Text is:
Run-time error '10086':
The external reference is invalid
(2,372 Views)
John;
I found a Knowledge Base about that error you can refer to. The KB, originally, talks about Labview, but, as Labview makes NI-DAQ function calls in the same way any other Software language, you can apply the same concepts when using VB. The link is:
http://ae.natinst.com/operations/ae/public.nsf/fca7838c4500dc10862567a100753500/2d8abbbb8d45ff74862565f6005c8d7b?OpenDocument
and the KB number is 18TAPEY5
in case you prefer to search for it at our home page.
Hope this helps.
Filipe
(2,372 Views)
