Multifunction DAQ
W95 system boot error: missing "nicfq32.dll"
We are re-installing an AT-MIO-16X card under Windows 95 with NI-DAQ Revision 6.1. Now at system boot we get the above message. When the DAQ software goes to the "initialization" phase after installation from CD, it terminates with an "illegal operation" error: the MAX is thus not installed.
The problem is VERY, VERY urgent
(2,564 Views)
Hello;
The best bet is to uninstall all NI-DAQ versions you might have installed on that machine; clean the window registry (you can delete the NI-DAQ folder from there, after you uninstall the driver); remove the board from the computer, reboot the machine, reinstall the driver, reboot again, and hook the board back to the computer.
Then, follow the steps of the link:
http://www.ni.com/support/install/
Hope this helps.
Filipe A.
(2,564 Views)
