Multifunction DAQ
Voltage could not dwell
Recently I am working on a little program to control voltage. A DC voltage can be control by the output signal of a PCIe-6341. The program control the high voltage power supple to change from zero to 7000V in 5 seconds, and be stable at 7000V at 5 minutes, and then come down smoothly to 0V in 5 seconds.
Now the question is, during voltage dwell, the signal does not stay on the last number. The signal voltage drops back to zero and make the high voltage back to zero. How to make the signal voltage stable at last reading and then to come down smoothly to zero?
Thanks!
(3,053 Views)
Thanks!
did you look at my last post to you? plus look at the Ni examples to generate your control voltage AO...under hardware input and output>daqmx>analog output>voltage
(3,047 Views)
Hi, apok
YES! However, I am trying to modify it. The voltage would not be stay at setting value.
(3,032 Views)
Accepted by topic author Kyle-Z
Thanks!
because you defaulted the value back to zero in the dwell case statement and you left out a shift register...
Spoiler
(3,010 Views)
Thank you !
(2,994 Views)
