Multifunction DAQ
Vernier SensorDAQ digital outputs activation with NI DAQ MX Python
Hi everybody.
I am making an application with the Vernier Sensor DAQ to control temperature in a closed mini-chamber with the LM35 and a light bulb  as an actuator.
To activate the light source, I need to configure and set a digital output of the DAQ for a certain time to keep the temperature radiating the focus. I'm using the NI DAQ MX Python API (https://nidaqmx-python.readthedocs.io/en/latest/)
Unfortunately I'm inexperienced with python and interpreting the documentation of that API, however I built this code, but when executing it does not activate any of the four digital outputs of the SensorDAQ:
import numpy as np
import nidaqmx as daq
import math
import pylab as plt
from nidaqmx.constants import LineGrouping
from nidaqmx import system
s = system.System()
print(list(s.devices)) # data dev correspondiente
def activa_salida_digital():
    #nidaqmx._task_modules.channels.channel.Channel
    #nidaqmx.system._collections.PhysicalChannelCollection
    app= 'Dev8/port0/line0'
    with daq.Task() as task:
        task.do_channels.add_do_chan(
            app,
            line_grouping=LineGrouping.CHAN_FOR_ALL_LINES)
        try:
            print('N Lines 1 Sample Boolean Write (Error Expected): ')
            print(task.write([True, False, True, False]))
        except daq.DaqError as e:
            print(e)
        print('1 Channel N Lines 1 Sample Unsigned Integer Write: ')
        print(task.write(8))
        print('1 Channel N Lines N Samples Unsigned Integer Write: ')
        print(task.write([1, 2, 4, 8], auto_start=True))
I attach the connection diagram:
Message 1 of 1
(2,384 Views)
