07-08-2005 09:52 AM
07-11-2005 01:50 PM
07-21-2005 10:12 AM
07-22-2005 11:04 AM - edited 07-22-2005 11:04 AM
Hello utplasma,
When you say "instrumentation assistant," you mean the DAQ Assistant, right? When you place a DAQ Assistant on the block diagram, a window should open which will guide you through the process of creating a DAQmx Task. Please see the screen shot below which shows the DAQ Assistant and where to find it in your function palette.
If you have placed the DAQ Assistant correctly and no window pops up (even when double-clicking), then I would try to reinstall your DAQ driver. Let me know how this works out.
Sean C.
Message Edited by Sean C. on 07-22-2005 11:13 AM
07-22-2005 12:20 PM
07-22-2005 01:07 PM
