03-07-2005 03:05 AM
03-07-2005 11:19 AM
03-07-2005 11:33 AM
03-21-2005 01:20 PM
03-22-2005 09:50 AM
03-23-2005 04:22 AM
@gus wrote:
Hello David-
It is possible to use the general purpose counters on the 6733 to generate a 10MHz pulse train, but it's a little more difficult than using the 4-bit frequency scaler. Generate a 5 MHz pulse train and then configure a counter output event to use pulse (instead of toggle). This should give you a 10MHz pulse train with a 50% duty cycle.
Let me know if you need help getting this configured.
gus....
03-23-2005 10:54 AM
03-24-2005 02:36 AM
@gus wrote:
The method I was describing would be using one of the 24-bit counters. Can you explain a little more about what your overall application is? How many pulse trains, what rates, etc?
03-25-2005 11:11 AM
03-29-2005 01:17 AM
@gus wrote:
Yeah David, it looks like the setup you have is as good as you're going to get unless you have another device in your system that could be used to generate the clock signal and then routed over RTSI. From looking at your specifications, I suspect that the 100kHz timebase won't work for you because it doesn't provide enough resolution, correct?
gus....
