08-02-2007 01:54 PM
08-02-2007 02:35 PM
08-02-2007 02:43 PM
It's been a long day man... If anyone needs me, I'll be the guy beating his head off the desk for not catching that :manmad:
Now it's at least showing 4v and 0 with a 10k. Is this going to work or do I need to keep messing around til I get 5? What do you think the chances are I screwed up the sensor by wiring it backwards?
08-02-2007 03:18 PM - edited 08-02-2007 03:18 PM
Yes, a 0 to 4 V range should work for the input. Looks like there is no internal reverse-voltage protection the the device, so yes, it could be damaged.
Try it out anyways and Good Luck.
edit- Don't bang your head too hard, you might lose your bearings
-AK2DM
Message Edited by AnalogKid2DigitalMan on 08-02-2007 01:20 PM
08-03-2007 07:14 AM
For some reason I can't get a reading with frequency or counter with this setup, although on the very same channel I can connect a Cherry Corp. proximity sensor and get accurate RPM and frequency. I'm thinking I've still got something wrong, even though the connections are right and I'm using the recommended 10k resistor. I'll try again with a new sensor, try the cherry again in hopes that I didn't hurt my board (it shouldn't have since it was referenced to its' own 5v source, right?) and report back. I may need some more assistance on this and thanks much in advance.
Ralph
