07-29-2011 02:26 AM
Hi All
I have got a USB-6501, and I want to use it as a frequency divider.
My clk generator output frequency is about 3MHz, but our system clk input frequency is 100KHz.
So I need a frequency divider factor about 32(2^5).
I had download the VI in the website: https://decibel.ni.com/content/docs/DOC-8644
Attached 1 is this VI.
When I tried to run this VI, some error occurred.
Attached 2 is the error.
In the front panel, I don't know which should be filled in blank of the counter I/O.
regards
07-29-2011 02:33 AM
The counter I/0 is described as:
Counter specifies the name of the counter to use to create the virtual channel such as the following :Dev1/ctr0.
I think this counter should be output, but when I change the I/O to be indicator, the path error occurred.
