06-27-2007 03:48 PM
I am working with the USB-6259 DAQ using the NI Digital Waveform Editor to simulate a controller on a bidirectional bus. I need to be able to generate and acquire data on successive clock cycles by tri-stating the DIO on the DAQ as supported by the hardware explained in the M-Series manual section 6-2.
I know in previous versions of the Digital Waveform Editor, it was required to stop all action on the bus, tri-state the DIO, and then resume action. E.g. load one waveform, tri-state, and then load another waveform.
I need to know if DWE 2.0 supports tri-stating the USB-6259 DAQ card fluidly. If so, how do I do it? Do I need to pull high DO.x Direction Control on the tri-state buffer via a separate signal line in DWE, or can I simply tri-state (“High-Z”) the DIO that I am reading/writing on then expect the data to be filled in?
Any help is appreciated, thanks.
06-28-2007 05:42 PM
Hi endoergic,
You should be able to simply set a high impedance level with the DWE and read and write using tri-state.
Let us know if you have any further questions.
07-02-2007 12:08 PM
I realize this may not be acceptable behavior for your application. If you need the ability to write data and tri-state the lines on the fly, all this being hardware timed, I recommend using the PCI/PXI-6551/2 devices. These devices will be able to implement the behavior you described.
Please let me know if you have any questions. I'll be glad to help.
Ryan
10-15-2021 03:00 AM
Hello everyone,
I want to use the DAQ card usb-6259-oem for my project. the Problem is, i actually don't know where i can buy it. I searched on NI-Website but i didn't find something.
Could you please tell me where i can find it?
Do you know a Card better than DAQ card usb-6259-oem?
thanks
Maestro-Roland
