Multifunction DAQ
Using USB-6210, relay, to control a 12V double solenoid valve
Hello there,
I am kinda new for the wiring of the relay. I have read some posts in forum regarding connecting the solenoid valve to the DAQ. But I am still not too sure how it all should be done. My objective is to use USB-6210, a crydom SSR (DC60 Series), to control a 12 V 5/2 way double solenoid valve for the extension and retraction of an actuator. I am just wondering how the schematic should be. Based on some googling, I come up with similar idea. Can someone give me some advice?
Since I have a double solenoid valve, I am wondering can I just wire one of the valve ( treating it as just a single
valve?) or do I need to wire both valves (which I am not too sure how) to achieve my goal?
Thank you so much in advance!!!!
(2,211 Views)
Anyone:( ...?
(2,169 Views)
please help 😞
(2,077 Views)
Looks good ..  output current of the 6210 is be sufficient to run that SSR.
Also the protection diode is included...
Greetings from Germany
Henrik
LV since v3.1
(2,062 Views)
Would you be able to help the labview schematic? I am kind new for using that and I am not too sure how to get it done...
(2,057 Views)
