Multifunction DAQ
Using PCI-6143 to acquire multipe current measurement
I am using a PCI-6143 to measure the current of 4 motors.
For every moto i need to measure current from 0 to 10s with 500 rate.
In my sequence i need to begin measurement of the current for every motors independly.
Si i created 4 tasks, every task for one motor.
The problem is that tasks i have the error "NI-DAqmx Error -50103 "The Specified Resource is Reserved".
I think it is beacause my tasks are concurrent, so i can't execute the 4 tasks in the same time.
I know a solution for that could be to combine all channels into one task but this solution wont work for me and I need these 4 channels to run in 4 separate tasks because I need  to use different trigerring for each input signal and if I combine them into one task it is not possible anymore.
Is there any way I can keep them running in separate tasks and also get rid of that 50103 error?
(371 Views)
Accepted by topic author MED_88
Briefly, No.
The workaround is to acquire continuously with all channels in 1 task while dealing with the equivalent of trigger detection in software.  The device itself simply doesn't support multiple simultaneous AI tasks with hardware-based timing.
-Kevin P
CAUTION! New LabVIEW adopters -- it's too late for me, but you *can* save yourself. The new subscription policy for LabVIEW puts NI's hand in your wallet for the rest of your working life. Are you sure you're *that* dedicated to LabVIEW?
(Summary of my reasons in this post, part of a voluminous thread of mostly complaints starting here).
(328 Views)
