02-19-2006 11:17 PM
I am trying to create a low power (only a few watts) data acquisision module for use in remote locations. I have been working with the USB 6008 & USB 6009 & USB 6051 multifunction DAQ modules along with a full fledged PC to design the application and make sure it works. I need about 32DIO, 8AI and 4AO. Now I am faced with making it consume MUCH less power. From what I can tell these are potential options - and why most aren't feasible:
1) PDA - low power, portable, nice screen. BUT NO usb host adapter or kernel driver. This would be my first option if I could use the 6008/6009/6051 modules.
2) Low Power PC - e.g. Nano-ITX - Runs full fledged Linux, or WinXP, but power consumption is closer to 15-20 watts. Too power hungry.
3) Linksys NSLU2 - Runs embedded linux - based on current kernels. Low power, built in USB host, plus ethernet controller. The COSMIC question - will any of the existing Linux support drivers work on this hardware? If they are kernel extensions, I would hope that they would.
Anyone have any insight into #3??
-Steve
02-20-2006 07:36 PM
02-21-2006 10:00 AM - last edited on 05-07-2024 02:18 PM by Content Cleaner
Hey Steve,
This sounds like a cool project. From what you posted it might be nice to know a little bit more about your requirements.
On your normal PC development machine are you using LabVIEW, or C as the programming language? Do you plan on using you same code, and simply moving it to a different low power platform, or are you willing to rewrite the application?
What operating system is your development machine running?
Also what driver are you currently using DAQmx, or DAQmx Base?
What do you plan on doing with the data you collect? Display it on a screen? Log it to a file? Transmit it to a remote location?
What is the time frame for this project? 1 month 1 year?
Here is my feedback on your suggested devices:
1) PDA - Some PDAs do have USB host adapter support. Examples: SL-C3100 (runs embedded Linux, ARM processor), NI TPC-2006 (runs WinCE, built in ethernet, supports LabVIEW PDA). Negatives for your applictaion: Our current Linux drivers do not run on the ARM processor. While we do have LabVIEW PDA, and DAQmx Base for the NI TPC-2006, DAQmx Base for PDA currently does not support our USB devices.
2) Nano-ITX - This should work fine except for your power requirements.
3) NSLU2 - Your biggest problem here is that our current Linux drivers do not support the ARM processor. They only work on x86 machines. It should be noted as well that on Linux our USB-DAQ devices are only supported through DAQmx Base. The DAQmx Base driver uses NI-VISA to communicate to out USB devices. All of this is done in userspace (as apposed to kernel space). I only bring this up since you mentioned "kernel driver" as a requirement for PDA.
02-21-2006 11:01 AM
On your normal PC development machine are you using LabVIEW, or C as the programming language? Do you plan on using you same code, and simply moving it to a different low power platform, or are you willing to rewrite the application? What operating system is your development machine running?
The development platform is WinXP on x86, using LabView. I am more of a scientist than a programmer, so I don't know much about C. The plan is to get it to function, then target whatever hardware will work with lowest power.
DAQmx Base - for no particular reason other than it is what appeard in the menus.
The data collected is a time series of ~400 data points over a few AI channels in a 2 minute period. The waveform should consist of a single ~gaussian peak about 30 seconds long that I integrate, and then display and store the peak area expressed in engineering units using a previously established linear calibration. Would be nice if the data is displayed near real time on a screen, but this isn't necessary. The data must be logged to a file, certainly the integrated peak area, but also the raw data if possible. I was also considering doing simple wireless transmission of the data to a laptop that would be within a few hundred feet for ~50% of the time. The data acquisition unit will be placed in some precarious and uncomfortable positions in the field - I would prefer to supervise the data collection from a laptop with no wires attached. I do not want to count on the wireless link to collect the data. It must be stored in a reliable format on the deployed device (CF, Hard Drive, etc.)
The mini/nano itx motherboard solution may work best. I can always lug out another battery to power the whole thing. I could plug in a keyboard/mouse/monitor and debug the thing real time on the enclosed computer - and would save retargeting and testing...
If I do go the nano-itx route - I would consider using Linux to save weight on the install instead of WinXP. Can you think of a reason not to do this? Every WinXP installation I do seems to have a zillion extra processes running that wouldn't be necessary on this somewhat embedded application.
I am doing design/build now. I hope to use this in the field in 8 weeks. Yikes.
-Speedy
02-21-2006 11:38 AM - last edited on 05-07-2024 02:20 PM by Content Cleaner
Ok a couple more questions/ideas. Why not use two laptops? Is it because of cost, size, or durability? Just a thought, but it seems like another solution from what you described.
If you went the route of the nano-itx then you would have two choices. Windows or Linux.
If you choose Linux you can customize your install so you only have what you need. Keep in mind that you will also need to purchase a copy of LabVIEW for Linux so you can run your existing application. Also since you mentioned minimal install you may want to consider building a LabVIEW executable so you don't need to install the LabVIEW for Linux development enviroment on the nano-itx. This would require that you either purchase LabVIEW Professional Development System or the LabVIEW Application Builder for Linux.
If you choose Windows you would probably have a more bloated install. However, if you already have LabVIEW PDS or the application builder for Windows then you could build a LabVIEW executable for your Windows target. Otherwise you would need to install a copy of LabVIEW for Windows.
Just to make sure this is clear... You can only build a Windows executable with the Windows Application Builder, and a Linux executable with the Linux Application Builder.
Shawn B.
02-21-2006 04:09 PM - last edited on 05-07-2024 02:20 PM by Content Cleaner
Yes, two laptops is an option. The reasons for not doing it are slightly higher cost and larger size. I looked into an ultracompact laptop - something like a Toshiba Libretto - but they cost upwards of $2K. The monitor probably will be unused most of the time, so that would be a poor use of power. I was also looking for something that could fit inside a small box. The 5" x 5" PC nano-itx could be strapped somewhere out of the way.
Yes, thank you very much for the clarification.
Message Edited by Speedy on 02-21-2006 04:10 PM
02-21-2006 09:29 PM
I just took a closer look at the TPC 2006. Wow does that look useful! I would buy one tomorrow if it supported the USB multifunction DAQ modules. Do you have any sense of whether such things are in the pipeline for release, or if there are no plans to support the USB modules via the PDA module?
02-22-2006 03:45 PM
04-03-2006 03:59 PM
04-04-2006 10:20 AM - last edited on 05-07-2024 02:21 PM by Content Cleaner
Hi bef,
While I am not sure the exact reasons why they haven't made this available, what I would suggest would be submitting feedback through our Product Suggestion Center here. Our R&D department receives this feedback directly, so they may look into any suggestions you have. Have a great day!
Thaison V
Applications Engineer
