Usb 6008 + LM35 temperature sensor problem
Hi, Mark,
I was desperate this morning before I saw your post. I am working exactly on LM35DZ and USB6009. I think I met the same problem with you. A real puzzle.
Actually I have two types of LM35. One is LM35DZ (To92) and the other is LM35Dm (SO8).
First, I did experiments on LM35DM. The pins are Pin 1(Vout), Pin4(Gnd) and Pin8 (+Vs). I connected Pin4 to two diodes (1N4148) in series instead of power GND directly. (Exactly as the Figure 7 in the NI PDF manual, see the attached PDF), I connected Pin8 to +5.8V (Output from a battery pack). A 18K resistor was connected to Pin1 as a small load. I measured the differential voltage between the Pin1 and Pin4. The output is perfect, equaling the room temperature multiplying 10 mV/C. I used USB6009 and Multimeter to cross validate the value.
However, when I did the same experiments on LM35DZ. The output is always between 0.31~0.33V no matter I cool the LM35DZ using a ice pack or a hot solder iron. I designed my PCB boards based on the experiments on LM35DM but it did work on LM35DZ. You can imagine how sad I was.
I cannot get good results on LM35DZ so I have to resort to LM35DM. I repeated the experiments, It works ok. However, when I connected the Pin4 (Gnd) to power Gnd instead of connecting to two diodes (Figure 1), the output becomes 3.75V.  It is Unbelievable.
I also tried to connect the LM35DZ pin 1 (+Vs) to +5.8V. Pin 3 (Gnd) to power Gnd (Figure 1). The output of Pin2 is also between 0.31V~0.33V. I tried 4 LM35DZs and got the same results.
I even doubted the NI LM35DZ is a temperature sensor.
Help me, please. Mark, If you get any progress on this problem.
East Star.
Message 21 of 44
(7,770 Views)
Interesting.
Mark- what is the input capacitance of the 6008/6009? The LM35's may get quirky above 50pF. Has anyone tried the decoupling/damping on pg 6 of the pdf supplied in the above post?
Message 22 of 44
(7,765 Views)
I tried Mark's method 1. It works.
The problem for me is that  I made a PCB to amplify this signal with difference to 0.25V. The temperature range I am measuring is around 20~30 degrees.
I have to find the problems of my PCB.
Message 23 of 44
(7,759 Views)
There are many figures on Pg 6. Which figure you mean?
Message 24 of 44
(7,759 Views)
Sorry, actually page 5, figures 3 and 4 and related discussion below them.
Message 25 of 44
(7,755 Views)
I am having a similar problem only using an LM20 as opposed to the LM35, and using the USB-6008.  I tried all of the suggestions listed eariler in this thread with no success.  The LM20 data sheet, like the LM35 suggested using the capacitance compensation for long line lenghts or high capacitance.  I tried this as well with no change in performance.
Specifically, the LM20 has a negative temperature curve and I am unable to get it to read above +66.7 degrees C or 1.06Vdc output.  Everything below that point works perfectly.  I have verified the software has the correct ranges, I checked the voltage at the input to the DAQ with both a meter and an oscope.  The meter reflected exactly what the DAQ card said, and the Oscope showed less than 25mVpp of noise.  My software is doing some averaging of samples, so the noise effect should be very minimal.
I am going to try some series resistance of a high value, and try a high value resistor at the input of the DAQ, but I don't hold much hope at this point.  Does anyone have any other suggestions?  I have also tried several new LM20s to be sure I wasn't trying to fix a bad temp sender.
Troy
Message 26 of 44
(7,493 Views)
