05-22-2006 10:39 AM
05-22-2006 12:22 PM
Hi Paul-
You will need to install a newer version of the NI-DAQ driver to include support for CVI 8.0. Traditional NI-DAQ (Legacy) 7.4.1 is available here.
Hopefully this helps-
05-22-2006 01:31 PM
05-22-2006 01:40 PM
Hi Paul-
The way to ensure that library is associated with CVI is by checking to see if the "Easy I/O for DAQ" library appears in your CVI library tree, the Easy I/O Library does not get added to the CVI library by default.
To add the "Easy I/O for DAQ" library, right click on the "Libraries" folder in the lower right hand window and select "Customize Library Menu." This will open a Menu window where you can add User Libraries. Select "Browse" and navigate into the bin folder. By default only .fp files are shown, so you will need to select "All Files (*.*)" from the "Files of type" pull down menu, then select the easyio.lfp file from the bin folder and click "Select". You will need to restart CVI for the changes to take effect. When you re-open CVI make sure that the "Easy I/O for DAQ" is shown in the library tree, if it is, you should be ready to go. Otherwise, you will need to try to add the .lfp again using the same method.
05-23-2006 04:12 AM
05-23-2006 09:07 AM
05-23-2006 09:50 AM
