I have a problem reading in analogue voltages with my DAQ6036E
When I use the Measurement and Automation Software I can read a voltage of say 7.5v without problem.
however if applying a signal of 7.5v to my VB6 software:-
AI_Read returns 32,767 and
AI_VRead returns 4.99v
voltages below 5v appear to measure correctly.
Literature indicates that being 16-bit bipolar the card should return -32,768 to +32,767 (16-bit devices, bipolar mode).
so 7.5v should be around 24500.
It would seem that the card is returning values on the scale 0 to 65,535 for 0 to 10v (16-bit devices, unipolar mode),
but the software wont accept values in excess of 32767, so anything in excess of 5v gives a result of 5v, but this is
only a theory.
I am using referenced single ended inputs and have used AI_configure to set this.
status = AI_Configure (deviceNumber, chan, inputMode, inputRange, polarity, driveAIS)
I have tried individual values for chan and also -1 to set all channels.
I have tried input modes of :-
0: Differential (DIFF) configuration (default).
1: Referenced Single-Ended (RSE) configuration. (The one I would expect to use and which works with the Measurement and Automation Software)
and
2: Nonreferenced Single-Ended (NRSE)
I have tried various input ranges - 20 being the value I would expect to use (-10v to +10v)
I have tried polarity 0 (bipolar) (The one I would expect to use) and 1 uniploar
and also 1 and 0 for driveAIS
I dunno what else to do. Help!
Alex
