10-23-2006 01:15 PM
10-24-2006 03:57 PM
10-24-2006 04:17 PM - edited 10-24-2006 04:17 PM
Hi David:
From MAX Help:
To create an NI-DAQmx simulated device, complete the following steps:
To remove an NI-DAQmx simulated device, right-click the device and click Delete.
On step 2 after clicking on Finish, that is where the error occurs. I never get a chance to select a device.
Message Edited by AnalogKid2DigitalMan on 10-24-2006 02:18 PM
10-25-2006 10:03 AM
10-30-2006 10:57 AM
Hi David:
1. How do I invoke the method you described? I am attaching a screen shot of my MAX panel, I cannot find the NI-DAQmx Devices property you mentioned to right click on.
2. I have Admin privileges on both machines.
3. I installed from my Aug 2006 Devel Suite CD's on both machines. DAQmx version shows up as 8.3.0f0 in MAX. If you can answer (1) above, then I will attempt a download of 8.3 in the link you provided.
This is my first ever attempt to use a simulated device.
10-31-2006 11:56 AM
10-31-2006 12:36 PM
David:
The plot thickens-
When I go to uninstall MAX via Add/Remove Programs- NI software, it detects dependant products that also have to be removed, basically most of the entire LV development system and ancillary applications.
Is there any other means of solely removing MAX by itself? This is most inconvenient in my opinion and not typicaly of removing application components in Windows.
Please refer to the attached screenshot of what has to be removed just to uninstall MAX. Since I could not resize the window, not displayed is that it also needs to uninstall NI-VISA 4.0 and NI-VISA Server 4.0.
-AK2DM
10-31-2006 12:46 PM
10-31-2006 02:56 PM
David:
Success- the DAQmx v8.3.0f3 download solved the issue. Looks like the v8.3.0f0 that shipped on CD has issues. I have created a virtual simulated device.
Sorry I mistook the need for uninstalling MAX, but still disconcerting that if anyone ever has to, they will have to dump and reinstall a lot of software (including LabVIEW).
Thanks Again
-Pete
10-31-2006 03:04 PM - edited 10-31-2006 03:04 PM
Message Edited by David S. on 10-31-2006 03:07 PM
