Multifunction DAQ
USB analog I/O
Hi all,
I have a question about USB DAQ card, more specifically about the 6212-6218 serie. My system would do an online loop-back over hours for a characterisation over time of a system.
One analog input channel is requiered for voltage measurement (around 200kS/s) and an signal generation channel 1kHz in the +-10V range. My question is the following, can those card generate a continuous signal without interruption over more than 2h ? IRQs ?  or is a PCMCIA a requierement for this type of application ?
glukix
(3,716 Views)
Hi glukix
take for example the "Cont Gen Voltage Wfm-Ext Clk.vi" which you can find
under Hardware Input and Output -> DAQmx -> Voltage in the example finder of LabVIEW.
So you can generate continuously a signal with the USB 6212 without interrupts.
best regards
Lars
(3,681 Views)
Glukix,
The USB-621x devices should not have a problem with these specifications.
Unlike typical multifunction USB DAQ devices, NI USB M Series (including the USB-621x devices) incorporate NI signal streaming, a patent-pending technology that provides multiple bidirectional high-speed data streams over USB. Without NI signal streaming, a multifunction DAQ device can only sustain a single high-speed data stream, effectively making it a single-function device.
The following document will give you a good idea as to how this technology works.
PCMCIA is not a requirement for this application.
Thanks!
Nathan Yang | Product Manager | Data Acquisition | National Instruments
(3,666 Views)
Dear all, thanks for the info
(3,660 Views)
