Multifunction DAQ
USB-9215A BNC error 200170
I am programming a little script/GUI with Matlab for some measurements and I get an window alert in reference to Runtime Libraries C++, if I press de OK button matlab crashes, if I wait some secondes I get a message error saying:
Error event occurred at 17:48:29 for the object: nidaqmxDev1-AI.
NIDAQmx error : Physical channel specified does not exist on this device.
Refer to the documentation for channels available on this device.
Task Name: MWDAT0253
Status Code: -200170
??? A timeout occurred during GETDATA.
Error in ==> NI_DAQ_SoundRecord at 15
data = getdata(ai);
Error in ==> fase_max at 5
NI_DAQ_SoundRecord
Error in ==> gui_fase_max>pushbutton1_Callback at 107
fase_max; % Run the script for calculations of Max & phase shift
Error in ==> gui_mainfcn at 75
feval(varargin{:});
Error in ==> gui_fase_max at 42
gui_mainfcn(gui_State, varargin{:});
??? Error using ==> gui_fase_max('pushbutton1_Callback',gcbo,[],guidata(gcbo))
??? Error while evaluating uicontrol Callback
Error event occurred at 17:48:30 for the object: nidaqmxDev1-AI.
My script for acquisition data from the card is very small and simple, I called each time that I need data:
SampleRate = 44100;
nfft = 1*SampleRate;
daqregister('nidaq');
ai = analoginput('nidaq','Dev1');
chans = addchannel(ai,0:1);
set(ai,'SampleRate',SampleRate,'SamplesPerTrigger',1*SampleRate); %'StartFcn',''
start(ai);
data = getdata(ai);
delete(ai);
clear ai;
That error code is DAQmxErrorPhysicalChanDoesNotExist, but I am using just 2 channels (addchannel(ai, 0:1);) and thats are channels 1 and 2 of my 4 channel card. This error came randomly when I am calling my script. I am using Matlab 7.2.0.232 R2006a, Data Acquisition Toolbox 2.8.1, Windows XP SP2, NI-DAQmx driver 7.5
(2,838 Views)
Accepted by topic author sopapo
Hi sopapo-
You may need to contact the Matlab people to see exactly how the implement the DAQmx Create Channel wrapper, but if you were working with the NI-DAQmx C API directly your channel string "ai,0:1" would be a problem.  I would suggest that you try "ai0:1".  Either way, you should check with them to see if their implementation requires the input parameters in a different format because NI neither supports nor has tested the Matlab toolbox for NI-DAQmx.
Hopefully this helps-
Tom W
(2,831 Views)
