Multifunction DAQ
USB-8451 not being recognized
Hello, I'm curious if anyone has gone through a similar situation. The USB-8451 was working perfectly fine until a couple of days ago. When I check device manager, the device doesn't even exist anymore. NI Max also doesn't register the device. The USB port supplies the voltage on the 8451.
I've connected it to other NI MAX/Labview based PC's and they can't find the 8451 at all. I tried another known good one with a different cable and it doesn't register either.
I reset the NI MAX database and reinstalled the USB drivers, to no avail. I'm relatively new to all of this, so i'm curious to know if this has happened to anyone?
(925 Views)
Did your Windows 10 update recently automatically? Have seen scenarios where a good working system is corrupt after a Windows Update.
Santhosh
Soliton Technologies
(906 Views)
