03-25-2009 02:57 PM
Hello all,
So, under Ubuntu 8.10 I have installed NI-DAQmx Base 3.2 using the method mentioned here. Firmware has been updated to NI-DAQmx Base 3.2 compatible using an XP partition on the same machine as discussed in several posts on this forum. When I run lsdaq under XP, the 6501 appears fine, however, this is not the case when lsdaq is run under ubuntu.
-`uname -r` yields:
"2.6.27-11-generic"
-`dmesg` after plugging in the device yields: (note, I have tried booting with the device plugged in as well as hotplugging)
" ... [ 816.136061] usb 2-1: new full speed USB device using uhci_hcd and address 4
[ 816.308527] usb 2-1: configuration #1 chosen from 1 choice ... "
-`lsmod | grep ni` yields nothing
-`lsusb` yields:
" Bus 004 Device 002: ID 049f:0086 Compaq Computer Corp. Bluetooth Device
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 004: ID 3923:718a National Instruments Corp.
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub"
- `ls -l /proc/bus/usb` yields:
"total 0"
-`lsdaq` and `sudo lsdaq` yield:
Detecting National Instruments DAQ Devices
Found the following DAQ Devices:
It seems that Mike might also be having a similar unsolved problem, but I decided a new post would be better than resurrecting an old thread.
If I've omitted any useful information, just let me know. Any help would be greatly appreciated.
-Ben
03-26-2009 01:35 PM
Ben,
Thank you for posting on the NI Forums. I am sure you have found by now that NI-DAQmx Base is not officially supported on the Ubuntu Platform. I was able to find this forum here where some individuals worked through getting a USB-6009 installed properly. There have been individuals who have gotten this to work properly but I know they went through some troubleshooting to get everything working. I would recommend completely searching the boards for others and what they have done to get their devices working. There is also a Linux User Community that you might look through as well. That site is here.
