Multifunction DAQ
USB-6451 Ungrounded differential connection (AI+/-) input impedance
Greetings! I'm performing some analysis on data that was taken with the above DAQ and method. In the specs, input impedance between AI+/AI- and AI GND is noted to be ">10 GOhms in parallel with 35 pF." However, since in the setup from which the available data was taken AI+ was connected to AI- without a ground connection (the device as a whole was grounded, but not the specific terminals used), I'm uncertain what the input impedance should be. I'm attempting to simulate voltage across the load attached between these terminals (using a divider circuit) so knowing the input impedance is important to increase accuracy of results. Is there any information on this device impedance available?
Thank you,
--JC
Message 1 of 1
(144 Views)
