Multifunction DAQ
USB-6363 not detected by NI-DAQmx on Ubuntu 22.04
Product: NI USB-6363 (multifunction DAQ)
OS: Ubuntu 22.04.5 LTS, kernel 5.15.0-194-generic
Driver: NI Linux Device Drivers 2026 Q3 (ni-software-2026-jammy), ni-daqmx 26.5.0.49618-0+f466, ni-daqmx-mio installed
The USB-6363 enumerates correctly at the USB/kernel level (lsusb: ID 3923:74fe National Instruments Corp. USB-6363; kernel log shows it detected with correct manufacturer/product/serial strings), but it is never claimed by any driver and never appears in NI's own device configuration database:
- lsusb -t shows no driver bound to its interface at all (Driver= empty).
- lsni (NI's own device-listing CLI) lists it only as a raw, unclaimed sysfs path, never as a named device.
- nidaqmx.system.System.local().devices (Python) returns an empty result for it — no error, just absent.
- No udev rule on the system references NI's vendor ID (3923) at all, so this doesn't look like a permissions/udev issue.
- Tried without effect: rebooting, udevadm trigger --action=add, a full USB re-enumeration via /sys/bus/usb/drivers/usb/{unbind,bind}, and restarting the nimxssvr (NI Configuration Manager) service fresh.
By contrast, on the same host, same driver install, an NI 9264 (via a cDAQ-9171 chassis) is detected correctly and fully usable (cDAQ1 / cDAQ1Mod1 via lsni and nidaqmx).
I found a community thread (https://forums.ni.com/t5/Multifunction-DAQ/USB-6361-Not-discoverable-from-NI-Hardware-configuration-...) where a similar report for the USB-6361 was resolved with "USB 6361 is not supported on any Linux version," per NI's own hardware/OS compatibility documentation.
Can you confirm definitively whether the USB-6363 has any Linux Desktop support — this driver release or any other — for direct USB DAQ use (not via a cDAQ chassis)? If it's genuinely unsupported like the USB-6361, is there a currently-supported USB-attached multifunction DAQ device (comparable AI/AO/DIO) you'd recommend as a Linux-compatible replacement?
(887 Views)
Same reply, it is not officially supported on any of the Linux distributions
If you're open to buying new hardware, USB-64xx series is supported in Ubuntu 22.04
Do you need an exact replacement in terms of number of channels? what is your requirement?
Santhosh
Soliton Technologies
(842 Views)
Accepted by topic author linux282
The mioDAQ line is the only USB DAQs that is supported in Linux. I was told the "legacy" USB devices had driver optimizations that only work in Windows and there is no plan to make these work on Linux.
(804 Views)
Thanks for the explanation!
We are not into buying new / other hardware at the moment so we'll have to find another way.
(681 Views)
